Board index Peugeot RCZ Peugeot RCZ Technical Discussion Interior rcz shift knob
rcz shift knob
Post Mon May 15, 2017 8:38 pm
Kudos: 1240
ONLY AEK wrote:
the knob is mine!!.
Wasn't it Michael Jackson that sang that? Or was it Rolf Harris :wtf: :oops:
Post Mon May 15, 2017 9:01 pm
Kudos: 596
Post Fri May 19, 2017 1:35 pm
Kudos: 74
OK the knob is not mine!
I ordered it from peugeot cheaper than ebay
Post Sat May 27, 2017 10:00 am
Kudos: 74
So i ve Changed mine too
One of the easyiest things i ve ever Done
Here is a video i found on YouTube
https://youtu.be/FZNcfn79NIk
Post Sat May 27, 2017 12:59 pm
Cuore Sportivo User avatar
Kudos: 69
Great video with unusual but effective 2 handed technique for knob pulling.
He looks quite a young guy though, and not sure I could do it as quick as him.
He also pulled a bit hard, and was lucky he didn't make a mess of his rooflining.
Post Sat May 27, 2017 11:41 pm
Kudos: 820
I see - he's holding the shaft in his attempt to pull it off!
I thought he had pulled off more than he could handle, but his youth made it look so easy.
Don't know if I could master**** his technique, like you say Cuore it's that technique which got him out of a potential sticky situation.
Post Sun May 28, 2017 6:56 am
Kudos: 1240
I couldn't pull it off as quickly as that, but that's probably cos I'm old now :roll:
Post Sun May 28, 2017 7:46 am
Kudos: 1240
On the plus side, if you take your time, and providing the out come is what you hoped for, there is a satisfaction at the end when you've done it yourself. ;)
Post Sun May 28, 2017 9:42 am
Kudos: 74
I used the Same technique
Put 4th gear so it doesnt move right or left hold it with one hand pulled it out with the other
It took me a couple of seconds
Post Sun May 28, 2017 10:29 am
Kudos: 69
Did you use any form of lubrication ?
Post Sun May 28, 2017 11:05 am
Kudos: 1240
The problem there can be it's difficult to get a firm enough grip to have the desired effect. :eusa-whistle:
Post Sun May 28, 2017 1:32 pm
Kudos: 74
No Nothing
It was so easy in this position that made me Wonder why you were All saying about brutal force...
Post Sun May 28, 2017 1:40 pm
Kudos: 69
No Nothing
In the Uk we sometimes find that lubrication helps.
I think the European spec Knobs pull easier due to the warmer climate.
Last edited by Cuore Sportivo on Sun May 28, 2017 4:05 pm, edited 1 time in total.
Post Sun May 28, 2017 1:46 pm
Kudos: 69
I think AEK is also very experienced in this area.
I asked a neighbour to help me pull mine in the end.
Post Sun May 28, 2017 2:43 pm
Kudos: 1240
It was good of AEK to post a video.
I had heard that it sometimes helps you to pull it off if you watch a video :eusa-think:
Post Sun May 28, 2017 9:38 pm
Kudos: 74
Maybe some of you must stop practicing with your sticks and Hit the gym for a while
Post Mon May 29, 2017 5:16 am
Kudos: 69
:D :thumbup:
