Board index Peugeot RCZ Peugeot RCZ General Active Bonnet reset cost
General Community Discussion - Anything RCZ
Post Sat Sep 22, 2018 2:43 pm
JokUK Regular
Partridge flew into car, active Bonnet deployed, any idea on cost to reset !! Presumably have to go to a pug main dealer
Black, 2010, 200 bhp GT
Post Sat Sep 22, 2018 3:11 pm
Kudos: 215
Only seen this once.
The car was written off, although it was in Australia so parts were probably more expensive.
Post Sat Sep 22, 2018 3:18 pm
Kudos: 649
Is there a warning on the dash? I wonder if you can get secondhand pistons to replace the blown ones they look like they just plug and play but I have seen two different types. :eusa-think:
Post Sat Sep 22, 2018 3:49 pm
JokUK Regular
Yes warning light on and bonnet not sitting flat ......
Post Sat Sep 22, 2018 4:27 pm
Kudos: 649
I thought it would need a re set I wouldn’t have thought that will be expensive it’s the but the pyrotechnic cartridges won’t come cheap just did a bit of research and it may be dangerous to work on the system so dealers it is I’m afraid :thumbdown: fingers crossed it’s affordable let us know how you get on. :beer:
Post Sat Sep 22, 2018 5:16 pm
JokUK Regular
Will do, fingers crossed
Post Sat Sep 22, 2018 7:30 pm
Kudos: 1198
Did you eat the Partridge :eusa-think: I think that’s the least you should have done to it :eusa-whistle:
Post Sat Sep 22, 2018 9:35 pm
JokUK Regular
Not much left of it after a few other vehicles finished it off !!
Post Thu Oct 11, 2018 11:16 pm
Kudos: 767
And a paaartrrridge in a RCZ....
Doesn't have the same ring to it does it ?
Post Fri Oct 12, 2018 12:43 pm
JokUK Regular
No...,...and a lot more expensive. Still can't get any sense from Peugeot on repair but my local is confident they can .......
Post Fri Oct 12, 2018 9:11 pm
Kudos: 767
Well good luck with that JokUK and don't forget to post the outcome and fix on here to help anyone else with partridge - sorry pedestrian pyrotechnics vandals.
Post Fri Oct 26, 2018 1:48 pm
JokUK Regular
Still no sense from Peugeot , last email stated 2 x hinges which are £94.42 each 2 actuators which are £395.48 each
1 capscrew which is 38p plus vat . But they couldn't say if this was parts only or included fitting.......still chasing.
Meanwhile my independent said he could do it, got costs from parts supplier but I found someone breaking rear damaged car and got hinges and actuators for £325. Just been fitted, all error codes reset fine apparently jobs a good un. not sure of cost yet but sure its going to be a lot cheaper. Just need to get dents out of bonnet where it flexed on activation !!
Return to Peugeot RCZ General
