Board index Peugeot RCZ Peugeotpedia replacing rear high level break light bulbs
Magnum Regular
Hello folks,
1. CAN YOU REPLACE THE REAR HIGH LEVEL BREAK LIGHT BULBS OR WILL I HAVE TO BUY A WHOLE BREAK LIGHT UNIT !
2. IF THE BULBS CAN BE REPLACED ARE THEY READILY AVAILABLE !
3. I TAKE IT THAT ACCESS IS VIA THE REAR HATCH LINING, DO THE PLASTIC LUGS SCREW OUT OR DO THEY POP OUT AND ARE THE SCREWS / LUGS :oops: RE FITTED BY SIMPLY PUSHING THEM BACK IN !
CHEERS FOR YOUR TIME PEOPLE, I LOOK FORWARD TO YOUR FEEDBACK.
Kudos: 457
Return to Peugeotpedia
