Board index Peugeot RCZ Peugeotpedia Access to Speaker panels
Post Mon Apr 01, 2013 12:58 pm
grafique Newbie
I've just got myself a year old RCZ HDi GT and all is good. :)
I just wondered if any of you guys has any info on gaining access to the speaker panels both front and rear, I have some rather good DB Audio Trex 6.1 (165mm) from my old Leon that I would like to fit?
Chris
Post Mon Apr 01, 2013 6:00 pm
jactac User avatar
Kudos: 508
I believe that like most modern cars the rear of the door card acts as weather seal, ie: they are sealed and designed to stop ingress of water that gets into the inside chamber of the door and help to drain away this water.
I would be cautious of just removing a door card, then thinking they just pop back on :eusa-think:
I changed the front door speakers on a Megan once and had constant water leaks afterwards, It had to go to a dealers in the end to have the door cards correctly re-sealed.
Front RCZ Splitters
380/360 Led DLR's
Post Mon Apr 01, 2013 6:03 pm
Kudos: 743
YIP door cards have to come off i watched this process whilst getting my front windows tinted and with 2 tools/levers its easily done to get them off to access the speakers. Prise them off from the top edge of door just above the outside door handle then work your way down to the bottom of the door they will fall off to a extent that you be able to access the speakers :thumbup:
Post Mon Aug 05, 2013 8:49 am
reycz95 User avatar
Kudos: 25
on commence par baisser la vitre puis on tire vers soit pour retirer la petite pièce en plastique en bout de porte
ensuite a l'aide d'un petit tournevis on fait levier sur l'entourage d'ouverture de porte
et hop
ensuite sur la grande poignée via la petite encoche idem levier avec tournevis
plus de cache on a donc accès au deux vis étoile
pour la commande rétro toujours pareil levier avec le petit tournevis
pour démonter la grosse cosse jaune tirer la partie bleu en arrière
pour les deux autre appuyer sur les zones striées
reycz95 User avatar
Kudos: 25
maintenant on ce muni d'une clef étoile de 20
une en haut
oui oui y'en a une aussi en bas :lol:
on vas en dessous de la porte pour démonter la lumière d’accueil
comme pour les autre cosses on appui sur partie striée pour le débrancher
ensuite on prend clef de 30
et on défait les deux vis de chaque coté de la lumière
via l'emplacement libre de la lumière on tire un coup sec de façon a faire sauter les clips
ensuite les câbles sont maintenu en place par des clips on tire dessus ils viennes tous seul, quelque prise a débrancher et on arrive là
Post Mon Aug 05, 2013 9:17 am
TomC User avatar
Kudos: 321
Removing to door cards is easy once you have seen it done. If not it's a nerves-wrecking job...
So, thanks for the photos :thumbup:
Tom
The blackest THP 200 of all...
Post Mon Aug 05, 2013 9:25 am
reycz95 User avatar
Kudos: 25
nothing if it can help
Post Wed Nov 26, 2014 12:24 pm
RCZ_123 Member
I need to replace my drivers side window, can everyone view the photo's to remove the door card/panel or is it just me that can't?
Post Wed Nov 26, 2014 1:05 pm
reycz95 User avatar
Kudos: 25
I even see my pictures of my taf while filtered
Post Wed Nov 26, 2014 2:15 pm
Showing fine on my iPad, might be your settings?
Post Wed Nov 26, 2014 3:51 pm
What are you trying to view it on? I can see them fine through Tapatalk but am not viewing the full site.
Post Wed Nov 26, 2014 5:53 pm
RCZ_123 Member
It's ok thanks - it was my internet settings which I have now changed can see the pics now
Is it worthwhile creating a how to change window blog if anyone is interested? as I have to do mine now thanks to someone breaking into my car
Post Wed Nov 26, 2014 11:20 pm
It all adds ro the knowledge of the forum. If no one needs it now, others may in future :)
Return to Peugeotpedia
