Board index Peugeot RCZ Peugeot RCZ Technical Discussion Lights & Electrics Inside Boot Courtesy Lights HELP please!? Common problem...?
RockyRCZ User avatar
I’ve searched and searched the web but cannot seem to find anything on the internal boot courtesy lights (one upper one right) which both appear to not be working :( on my recently purchased 2010.
I’ve removed both lights and replaced both bulbs (twice) checked any relevant and some irrelevant fuses (thrice) and can’t seem to find the problem with it.
All other courtesy lights in the car are functioning and all visible connections seem fine so was just wondering if there was anything else I should check/ if anyone else has had this issue ?
As I can’t find any info at all anywhere and didn’t want to miss something obvious before I pull out the entire boot and chase all the wires :/
Thank you!
Newly enjoying life on the Z side :D
If they are both not working, maybe it’s the switch that is it operating correctly?
Kudos: 581
I would have thought both lights will work off the same switch :eusa-think:
Sorry, yes that’s what I meant, maybe it’s the switch that controls both lights that is faulty. I’m not sure where it’s located for the boot lights though, not something I have ever noticed :eusa-think:
The boot lights are the same as the puddle lights in the bottom of the doors.
It might be the light itself.
Plug it into the door if the puddle lights work to see if the lights work.
Then if they do, you know it's wiring related or boot switch!
Sent from my SM-N9005 using Tapatalk[/quote]
That was my second thought! I believe they operate off of the boot sensor which i've assumed is the rubber ended short pole sticking out next to the boot securing lock mechanism. Logic would have that this same sensor would illuminate the inner car warning to an open boot whilst driving so maybe i'll see if that is actually functioning...
Ohh i actually had not even thought of that!! Thanks so much- fab idea, will definitely try!
