Board index Peugeot RCZ Peugeot RCZ Technical Discussion Lights & Electrics Earthing point in glove box?
Post Mon May 21, 2018 11:09 am
Agis User avatar
Hi guys,
I am trying to hardwire a dash cam in the fuse box but can't find an earthing point in / around glove box.
Any suggestions?
Agis
Post Mon May 21, 2018 3:37 pm
When I've woken up, done my chores and cooked tea I'll see if I can contort myself in to a position under the dashboard and take a picture of the earth I used.
This will come with a massive caveat though, I am the biggest bodger in history. So whether you choose to emulate my choice of earth point is entirely up to you.
Post Mon May 21, 2018 4:35 pm
Agis User avatar
Hahaha fair enough mate. Show me the way :-)
Post Mon May 21, 2018 7:00 pm
The red sleeved cable. This is in the footwell, been fine on there about a year.
Post Mon May 21, 2018 9:50 pm
You could also run an earth to the heater framework, behind the audio / head unit.
If memory serves me well, I'm sure there is an earth wire terminated there already.
Post Tue May 22, 2018 12:01 am
The yellow and green wire in glove box.
You can see where I've had a "scotch lock" on (circled in red).
Check for continuity, on a definite earth in engine bay (this one is for jump leads in manual).
Post Tue May 22, 2018 1:17 am
Agis User avatar
Thank you very much guys. I ended up taking the glove box out then stripped the left side of the dash board to run the wires hiden in the left column. In there I found bare metal and screwed the ground wire on it.
I have taken photos but the system won't let upload them. Standard jpg images aren't compatible with this board?
Post Tue May 22, 2018 11:43 am
Pictures have to be less than 256kb ?!?
Or you can use the tapatalk app as it re-sizes it for you.
Post Tue May 22, 2018 11:47 am
Agis User avatar
Sending these through TapaTalk
Sent from my D6503 using Tapatalk
