Board index Peugeot RCZ Peugeot RCZ Technical Discussion Lights & Electrics Permanent and Ignition Power
Post Mon Jan 16, 2017 10:41 pm
Wimmy1 User avatar
Hi all,
Newbie here. Owned my RCZ for 18 months (11 plate diesel) and popped on here for the 1st time. I'm trying to hardwire a Thinkware F770 dashcam and using two piggyback fuse taps. I needs a permanent 12v and an ignition switched 12v. Can anyone point me in the direction of the correct fuses?
Post Mon Jan 16, 2017 10:54 pm
Post Mon Jan 16, 2017 11:12 pm
Wimmy1 User avatar
Thanks for that. However, I was looking to simply tap on to a couple of existing fuses rather than butchering on to a couple of wires. I have routed all the cabling to the fusebox (and earthed behind glove box) and just need an ignition powered switch. All seem to be permanently on :s
Post Mon Jan 16, 2017 11:32 pm
I fitted front & rear Dashcams, piggybacking fuses. I honestly can't remember which ones I ended up using, but I went for ignition controlled for both. I remember just using the trial and error method, as it doesn't matter what fuse you choose - because its piggy backed, the original fuse rating will still apply to the circuit it was intended for. The only time that wouldn't apply is if the original fuse was lower rated than the Dashcams, but as the Dashcams fuses are rated so low, that wasn't an issue.
If I get chance, I will have a look tomorrow and maybe take a photo.
Post Mon Jan 16, 2017 11:34 pm
Wimmy1 User avatar
Thank you! :)
Post Tue Jan 17, 2017 8:37 am
I think I did another post where I or someone else fitted cameras and went through which fuse I used and which earth in the fuse area I used.
Post Wed Jan 18, 2017 6:47 pm
Wimmy1 User avatar
For future reference for anyone
F6 for BATT
F3 for ACC
Works a treat. Lets just hope the permanently installed dash cam doesn't tempt the scallies to pop a window!
How good is your rear view camera? I have the option of purchasing as an add on for mine but can see it being not much use in any type of wet weather due to the shape of the rear window and no wiper.
I'm Manchester based so it rains here most of the time
Post Wed Jan 18, 2017 11:34 pm
My rear screen's video is the same quality as the front.
If there is water vapour or rain drops on the screen when i start moving it run off and the camera can see out of the top of the screen, get some great views of the water cascading down the screen.
Post Thu Jan 19, 2017 1:54 am
Mine is fitted centrally at the top of the screen. Obviously if it is steamed up then there is nothing much to see, but as Chris has said, the water run off clears the outside quite quickly & is quite a sight on playback.
Sorry I didn't get back to you, but I haven't had the car for the last couple of days, my OH has been using it.
Post Thu Jan 19, 2017 12:58 pm
Not going on the forum, or Facebook, or Internet, pining after your car, worried about it, hoping it doesn't get muck, or damaged, oh the joys of owning a RCZ.
Have you re-viewed the footage yet to see how the RCZ was treated?
:oops: :oops: :oops: :mrgreen: :mrgreen: :roll: :roll: :lol: :lol: :D
Post Thu Jan 19, 2017 2:15 pm
I daren't look in case of what I might see :o
But I did get chance to give it a good fettling this morning :D
Post Fri Jan 20, 2017 10:06 am
Wimmy1 User avatar
I daren't look either unless it gives me an 'incident' notification
Post Sun May 14, 2017 6:28 pm
ecion Newbie
F6 for BATT
F3 for ACC
Give that man a beer. :beer: I was very confused to find the v12 socket and windows fuses were giving power without ignition. Using F3 sorted it!
2014 RCZ GT 2.0HDi with RT6
