Board index Peugeot RCZ Peugeot RCZ Technical Discussion Lights & Electrics Success with LED daylight running lights?
nicpy Member
Kudos: 19
Has any one had any luck with fitting 21/5w LED daylight running light/side lights. I have tried a few now, the last ones came from Hids Direct which were supposed to be canbus error free etc but still showed a fault on the display and on Diagbox. The lights worked ok but it would be nice to find some that don`t show up as being faulty. :helpme:
I've been running LED's in our MK1 for 2 yrs now with no issues.
I think it was these ones but i can't find my email anymore about the order: http://www.ebay.co.uk/itm/1x-80w-1157-B ... 1565182102
Sanity Senior Member
I bought mine from rczperformance here on this forums over a year ago. working great with no issues at all.
nicpy Member
Kudos: 19
I tried these, but unfortunately they still produce a fault code, they are supposed to be Osram and Canbus but I have my doubts. Thank you for the help anyway. :thumbup:
nicpy Member
Kudos: 19
Delighted to say that these do the job;
http://www.autobulbsdirect.co.uk/380-Tw ... -Bulb.html
There are no faulty sidelight warning messages in the warning log on the car, double checked using Diagbox and that is clear. The bulbs dim down as they should on sidelights. :clap:
(should point out this applies to pre-facelift RCZ)
