Board index Peugeot RCZ Peugeot RCZ Technical Discussion Lights & Electrics Airbags or pre-tensioners
Post Wed Aug 31, 2016 1:14 pm
RCZ_123 Member
Well done, good find and fix.
Post Sun Mar 26, 2017 3:59 am
andrerolopes Newbie
Hi nicpy,
I have the same problem in my Z since yesterday. Can you tell me how you fixed this issue (did you do it yourself or had to have it fixed at a repair shop)?
Thanks mate
Post Sun Mar 26, 2017 6:27 am
nicpy Member
Kudos: 19
I did the fix myself. Access to the connector isn`t that easy, but is doable, from underneath is the easiest but done more by feel than sight. You will need to remove the front part of the under shield, on the driver’s side behind the grill about half way up there is the connector for the pedestrian impact ribbon sensor, which was my problem, and this had become partially disconnected. Not the easiest thing to do because of the angle but it needed a good push on so that it clicks securely in to place. That did the trick for me. :beer:
