Board index Peugeot RCZ Peugeot RCZ Technical Discussion Ipods, MP3 Players and Sat Nav R pop up display
R pop up display
Post Thu Mar 29, 2018 5:10 pm
Mrker50 Member
Kudos: 12
Hi.when i leave the R locked in the garage for a few days then go to start her it says emergency mode and the pop up display does not open.
Unless i press manual open.
It opens and closes normal after that is that normal ? Cheers
Post Thu Mar 29, 2018 5:24 pm
Economy mode? Battery needs charging or replacing.
Post Thu Mar 29, 2018 6:10 pm
Mrker50 Member
Kudos: 12
Thanks.it only when its been left for say 4 days
Post Thu Mar 29, 2018 7:13 pm
Kudos: 1158
+1 RCZ’s hate batteries with a low charge. Loads of issues on here have been solved by replacing the battery. It’s certainly worth having it tested before going down the diagnostic route.
Post Thu Mar 29, 2018 7:22 pm
Kudos: 1482
I don’t use my R every day any more due to a change in job so I’m able to walk to work. This means my R is stood for a full week or sometimes longer and I’ve never had the screen not open up automatically. It does sound like your battery needs checking and possible replacement.
Post Thu Mar 29, 2018 7:49 pm
Mrker50 Member
Kudos: 12
Thanks not 3 year old yet.but dont think that will be covered.but screen not opening should be ??
Post Thu Mar 29, 2018 8:11 pm
Kudos: 1158
It all depends on whether the cause is the battery. If it is, and the battery is not covered (probably, almost definitely not) then when the battery is replaced it should cure the screen issue.
If the battery is not at fault, then yes, the screen not opening should be covered under warranty.
My Z is coming up to 5 years old, it still has the original battery. However, recently, there have been a couple of times when starting the car up, the screen hasn’t opened for maybe 30 seconds to a minute. Other times, the screen has opened, but the software seems to take an age to start up before any music plays.
Sometimes, the music plays almost instantly on start up.
Maybe mine is starting to get a bit worn.
Post Thu Mar 29, 2018 8:26 pm
Mrker50 Member
Kudos: 12
Thankyou.is it just a case of swapping over if main dealer says battery no good ?
On my boxster it did not like a battery taken off.so i connected my ctek while doing it as the fag lighter is constant live on them.
I got porsche one from halfords as was best price for the quality i wanted.
Post Thu Mar 29, 2018 9:42 pm
Yes you are correct they do not like the battery taken off willy nilly, you have to do it a certain way to ensure no errors creeping in.
This is the procedure for resetting the BSI and disconnecting battery, check first with other members but I'm sure this is right.
Put the driver’s window down, lift the bonnet and ensure all
equipment is switched off.
Ensure all doors are closed and remove key from the
ignition.
Wait for 3 minutes, disconnect the vehicle battery and wait
15 seconds.
Reconnect the vehicle battery, wait a further 10 seconds (do
not open doors.)
Switch on the side lights through the driver's window.
Switch on the ignition and check system’s functionality.
Hold lock button on key down for 10 seconds.
remove key open & close door test central locking system
Start the engine and complete the system’s check.
Failure to follow this procedure could result in incorrect operation of many
BSI related items.
This was nicked from an earlier posting.
Post Thu Mar 29, 2018 10:00 pm
Mrker50 Member
Kudos: 12
Thanks.if its goosed i mite have swapped at dealers then
Post Sat Mar 31, 2018 9:16 pm
My RCZ-R is only just over 2 years old. I've just done a run to Scotland (400 miles), locked up the car over night, came to it this morning and opened the boot once.
Came back to it and went to start it economy mode came up.
This mode is to allow the engine to start by shutting down all unnecessary usage.
My RCZ-R has been doing this since its first winter but still starts the engine.
Post Sun Apr 01, 2018 1:12 pm
Kudos: 65
When the car wont start, it Will be too late
