Board index Peugeot RCZ Peugeot RCZ Technical Discussion Interior AirCon Problem
AirCon Problem
Post Mon Jun 29, 2015 4:55 pm
McWilliamss Newbie
Hello All with Knowledge about PEUGEOT RCZ GT THP 156 COUPE BLUE, 2010 year.
SO I'm Here because Have a problem with my A/C.
Heating works Perfect (from 17 till HIGH), but when Try Use my AirCon it give a Hot Air flow...
I was in Peugeot Service to Top-up my Coolant now is Full Charged and after this they said my AC still not working..
Car Computer doesn't Show Any Error Or Fault (checked on Peugeot Planet 2000)
tested AirCompressor levels by Digital Multimeter and when is turned OFF it show 0.00 when switch ON it show just 3.57V think should be 12V..
AirCompressor tested on 12V and i hear "Click" so its OK.
anyone know maybe if there can be any transmitter for electricity which is going to Pump?
Post Tue Jun 30, 2015 5:54 pm
Kudos: 368
Is the radiator holding refrigerant?
Post Wed Jul 01, 2015 10:34 am
McWilliamss Newbie
Yes gas is full charged and radiator keeping refrigarant.
Post Fri Jul 03, 2015 8:57 am
McWilliamss Newbie
Any1 have maybe scheme of all A/C system...corect Volts in pump cables etc? Please help Me.
Post Fri Jul 03, 2015 10:33 am
Kudos: 1042
Sorry, I'm not ignoring you, it's just beyond anything I could help you with.
In my experience from previous cars, aircon faults have been due to re-gassing being required, or compressor faults. You seem to have covered these areas.
I have no idea about the voltage input for compressors. Could you bypass the electrical input, and try a direct 12v feed to the compressor? Or maybe a call to a Pug service dept might help, although they will probably just ask you to take it in.
Maybe a new compressor is needed, hope not, cos that would have cost me a fortune on my last car Megane CC but as it had been a continuing issue from new, Renault paid, even though it was way out of warranty. They seem much better than Peugeot for that kind of thing.
Sorry I can't help. Hope you get it sorted, the Z cab is a hot place in this weather.
Post Fri Jul 03, 2015 10:51 pm
Kudos: 368
you may take it to the dealer and get them to check the compressor or check for leaks. it might not be as expensive as you think.
