Board index Peugeot RCZ Peugeot RCZ Technical Discussion Interior Sat Nav Problem
Sat Nav Problem
Post Thu Jan 16, 2014 6:33 pm
Jimbrodie1 Senior Member
Kudos: 70
Anyone had a problem with the Sat Nav screen picture breaking up (just as it would if the reception wasn't good enough) like the picture you would get on your TV with a dodgy Ariel.
Did it a couple of times yesterday, then came good again. I've had many cars with Sat Nav before and never experienced this, which makes me think it a hardware problem and not simply poor reception ?
Post Thu Jan 16, 2014 9:35 pm
Kudos: 894
I have used mine a lot over the past 3 years and not experienced this issue
Post Thu Jan 16, 2014 10:02 pm
jactac User avatar
Kudos: 509
NG4 Sat Nav / Media screen, went a bit "fuzzy" fews days ago, but just for a second or so.
It happened almost as soon as I started the car up, so I put it down to that :eusa-think:
Front RCZ Splitters
380/360 Led DLR's
Post Thu Jan 16, 2014 10:09 pm
Kudos: 70
Yep,sounds the same as mine only mine stayed like it for about 3 or 4 mins. I put it down then back up about 10 kind later when a call came in and it was OK ???
Post Fri Jan 17, 2014 10:13 pm
bobbythedog User avatar
Kudos: 80
Had this on my car almost immediately after buying it (second hand) back in July. Mine got progressively worse over the space of a month and finally had it replaced under warranty. Took a couple of hours. They said it was a wire shorting when the screen rotated. Think others have had it happen once and then never again. Luck of the draw..... So finger s crossed for you
Sent from my GT-I9300 using Tapatalk
Post Fri Jan 17, 2014 10:29 pm
Kudos: 70
Thanks for that.
It only happened on that day so far so I'll keep an eye on it. Still got 14 month on the factory warranty so if it's going to go it should do within this time.
Post Wed Jan 22, 2014 6:28 pm
jactac User avatar
Kudos: 509
This has happened again today :eusa-think:
It stayed jumping and fuzzy until I manually lowered the screen, then raised it back up.
This only happens when the car is first started, but not every time . :eusa-think:
Looks like another visit to the dealer is on the cards :thumbdown:
Front RCZ Splitters
380/360 Led DLR's
