Board index Peugeot RCZ Peugeot RCZ Technical Discussion Interior Heater not working!
Heater not working!
Post Thu Mar 08, 2018 3:05 pm
queenb123 User avatar
Hi it’s bloody winter and the heating has stopped working - or not as it usually was.
Car has only 11k miles
Car has water and other relevant fluids
Car was fully Serviced October 2017
I was told that I need to fill up the gas canister for air con only - does this affect the heating?
Pls help!
Love my rcz but hate expensive repairs!
Post Thu Mar 08, 2018 3:17 pm
the refrigerant is only required if you use a/c. this should not prevent the ordinary blower heater from working and putting out hot air. have you checked the fuses under the bonnet that relate to the heater control unit? check in the handbook and it will show you which fuse covers the heater.
Post Thu Mar 08, 2018 4:12 pm
JvdBosch Regular
Does the temperature reach it's normal level? If not, or too slowly: broken thermostat.
Red RCZ-R, 8000km and counting...
Post Thu Mar 08, 2018 4:15 pm
Everything seems to be fine - no electrical faults or warnings!
Post Fri Mar 09, 2018 4:38 am
The bf has had a look at it...been told its a broken thermostat - lets hope so as i've had no faults or warnings from the car!
