Board index Peugeot RCZ Peugeot RCZ Technical Discussion Interior Heated seats
Heated seats
Post Thu Mar 23, 2017 5:39 pm
Scotty2Hotty Regular
Wasn't sure where to put this so hope it's right.
Does anybody else find that the dial turns itself on. Or should I say I end up turning it on somehow and only realise when it's taking ages for the engine to warm up.
Is there a way to deactivate it as it's not something I ever use? Or would the best way be to remove the fuse? If so does anybody know which one it is?
Cheers
Sent from my BV6000 using Tapatalk
Post Thu Mar 23, 2017 7:15 pm
Kudos: 882
This topic has been covered a few times before, or rather the question of whether the heated seat dial turns itself off when the car is turned off.
The positioning of the dial means that when you get in & out of the car, your leg catches the dial and turns it on, or off.
I am not sure why you think that the seat heater causes your car engine to take longer to heat up? :eusa-think:
