Board index Peugeot RCZ Peugeot RCZ Technical Discussion Interior Aircon not working?
Aircon not working?
Post Sun Aug 07, 2016 6:00 pm
Gedget Regular
Kudos: 7
Hi guys,
Wondering if anyone could help me.
The aircon system is not working on my RCZ.
At workshop we put new gas on it, but we found out that no energy reaches the aircon compressor, so obviously it does not engage.
We checked the fuse panel, and fuse is ok, but also no energy there!
My local workshop suspects the fuse box is damaged, as they told me this is called BSM module (or something like that) and it usually gets damaged.
Any ideas what it could be the problem?
We run out of ideas. Also PP2000 does not show any error.
Post Sun Aug 07, 2016 8:02 pm
No idea if it would help or not, but you could try a BSI reset. I know it has resolved some weird and wonderful issues in the past. :eusa-think:
Put the driver’s window down, lift the bonnet and ensure all
equipment is switched off.
Ensure all doors are closed and remove key from the
ignition.
Wait for 3 minutes, disconnect the vehicle battery and wait
15 seconds.
Reconnect the vehicle battery, wait a further 10 seconds (do
not open doors.)
Switch on the side lights through the driver's window.
Switch on the ignition and check system’s functionality.
Hold lock button on key down for 10 seconds.
remove key open & close door test central locking system
Start the engine and complete the system’s check.
Failure to follow this procedure could result in incorrect operation of many
BSI related items.
Hope this helps
Post Sun Aug 07, 2016 9:35 pm
Dean6 Member
Kudos: 7
I was having the same problem. I had every check done by Peugeot but still nothing got sorted.
Took it to an auto electrician and he found the problem in 2 minutes. It was a loose wire going to the compressor...
Post Sun Aug 07, 2016 11:28 pm
Sounds easier (and more likely) than the BSI reset ;)
Post Mon Aug 08, 2016 1:39 am
Gedget Regular
Kudos: 7
Will try the above suggestions.
We could even try to power directly with 12V the aircon fuse, but we didn't do it, because we were afraid burning something..
Post Wed Aug 17, 2016 9:00 am
steve2201 Newbie
Try the yellow connector joining the car wiring move it around a little and you will hear the compressor kick in. That's where my problem lies
