Board index Peugeot RCZ Peugeot RCZ Technical Discussion Wheels, Tyres & Brakes and Suspension Screech
Screech
Post Fri Sep 20, 2013 7:15 pm
photojohn User avatar
Kudos: 151
Hi guys,
Did a 350 mile trip back up north today. Car sat for around 3hrs when I got herr. Just done a short trip round town and the brakes are screeching everytime I touch them.
Any advice on the reason gratefully received :smile:
Sent from my GT-I9300 using Tapatalk 2
Post Fri Sep 20, 2013 8:19 pm
xzibit206 Senior Member
Kudos: 46
mine do the same at times. It's from one of two sources,
- Your brake pads are worn out and it's metal on metal (unlikely unless you have a huge mileage)
- Your discs and pads have reached a point of wear at which they resonate at an audible frequency and there is sod all you can do about it
Try braking a little harder, usually it's only when I'm barely touching the brake pad that it makes a noise. I wouldn't advise putting on sprays or anything else to try and "lubricate" the squeal away. As I'm sure you can imagine this isn't a great solution........
Edit - would changed to wouldn't
Gary , Nera Black 156 GT
Post Fri Sep 20, 2013 8:28 pm
Kudos: 151
Well the Cars only 2 weeks old so it's not worn parts. Have noticed the disk get a coat of rust over night .
Maybe a bit of copper grease will do?
Post Fri Sep 20, 2013 8:54 pm
Greasing discs?? ARE YOU MENTAL??? :eusa-think:
Mine do it too, usually when sitting in traffic under light pressure. Amber's just been serviced so I know the pads/discs are ok.
Kudos: 46
NOOOOO!!!!!!!!!!!!!! NEVER EVER EVER PUT GREASE ON BRAKES!!!!!!!!!!!!!
Brakes work with friction. Take that friction away and you might as well cut the brake lines.
The fine coat of rust is normal. Happens to mine when it either gets wet or I wash it. It's a light surface coating that disappears quickly.
If you are seriously annoyed by the squeal then you could try changing the brake pads to another type or material but I doubt you'd want to pay for the expense.
Post Fri Sep 20, 2013 8:56 pm
To be fair Gary ...your first reply said "I would advise" but I know you meant "I wouldN'T advise" :)
Post Fri Sep 20, 2013 8:59 pm
Hmmmm...this is a little puzzling given the age of the car. I'd get it checked out.
Post Fri Sep 20, 2013 9:03 pm
Kudos: 46
Sugar, thanks for the spot! That's what I get for posting on my phone :)
Post Fri Sep 20, 2013 9:24 pm
Kudos: 151
Lol guys. Copper grease doesn't go on the disks or pads. It's for the components of the brakes. I was thinking that one or more if the calipers could be sticking, causing the screech. So copper grease tge caliper to make sure it's free abd moving as it should.
Although wd40 on the disks does sound fun lol. :-?
Post Thu Sep 26, 2013 5:38 pm
Kudos: 258
You need new and better brakes, and we sell them ;)
Post Thu Sep 26, 2013 6:05 pm
Kudos: 743
You may have debris trapped on the pads mate this will scratch the disc's ,look for deep un even grooves on your front discs
Post Thu Sep 26, 2013 6:07 pm
Kudos: 151
Thanks Jassy, I hadn't even considered that! Will check them over this weekend. Cheers mate!
