Board index Peugeot RCZ Peugeot RCZ Technical Discussion Wheels, Tyres & Brakes and Suspension tyre worn in middle only
Post Fri Jul 13, 2012 1:03 pm
njdrabble Regular
Kudos: 8
Just noticed that my front off side tyre is showing a lot more wear to the tread in the middle of the tyre as opposed to the outside edges. I am very careful with my tyre pressure so it's not caused by overinflation. Any ideas what could be causing this before I replace with a new (expensive) tyre.
Post Fri Jul 13, 2012 1:07 pm
Scott barton User avatar
Kudos: 113
Over inflation is the usual cause.
I know you said you checked pressure. But what ate you putting in their?
Post Fri Jul 13, 2012 1:13 pm
njdrabble Regular
Kudos: 8
She gets 2.4 in the front. Check them every 4-6 weeks, always when cold.
Post Tue May 21, 2013 8:47 pm
rcz_pete Newbie
This may come a bit late but anyway:
tyre overinflated -> tyre wears out outside edges
tyre underinflated -> tyre wears out in the middle
When tyre is underinflated, tyre is too loose to keep its form when rotating fast. Centrifugal forces will get tyre deformed the way that center part of the tyre will move away from the center of rotation. Simple as that.
-pete-
RCZ THP 156 2012
Harian Grey
Limp Mode
Post Wed May 22, 2013 6:41 am
I don't usually work in "new money" when it comes to tyre pressures .... I'm a PSI girl .... 34 all round
Post Wed May 22, 2013 9:13 am
jactac User avatar
Kudos: 508
I know you said you checked pressure. But what are you putting in their?
Put air in is the best bet, you could try custard, but I recommend air :lol: :thumbup:
Front RCZ Splitters
380/360 Led DLR's
Post Wed May 22, 2013 9:16 am
jactac User avatar
Kudos: 508
-pete-
I have to say , this is the first time I've heard of this, not saying it's incorrect but I've not heard this before.
Every time I've taken a tyre in to be replaced because of "centre" wear, the fitter has said over inflation :eusa-think:
Take a look at this guide.
www.procarcare.com/includes/content/res ... ewear.html
Front RCZ Splitters
380/360 Led DLR's
Post Wed May 22, 2013 9:55 am
I prefer nitrogen to air as it give better results IMO
Post Wed May 22, 2013 10:35 am
JWT User avatar
Kudos: 96
I fill mine up with a gas made of 78% nitrogen for free with unnoticeable differences.
Post Wed May 22, 2013 4:27 pm
Sorry RON but that's total nonsense. Maybe if you were driving an F1 car or flying aircraft. See the article below!!
http://www.theaa.com/motoring_advice/sa ... rogen.html
Post Wed May 22, 2013 4:40 pm
bigmac3161 User avatar
Kudos: 732
They put nitrogen in the tyres on a tv show and the car actually handled cornered and braked worse on nitrogen than standard air so smoke on that when air free
PURE WHITE VOLKSWAGEN GOLF R
BORN JULY HOPEFULLY
18" CADIS ALLOYS
Post Wed May 22, 2013 6:29 pm
MaX83 User avatar
Kudos: 215
I heard about that test, 5th gear i think... cant comment though as i've never used nitrogen in my tires before.
Current: 2013 Peugeot 308 GTI THP 200
2013 BMW 328i(A) F30 M-Sport
Ex: 2013 Peugeot RCZ THP 200
2011 Citroen C4 THP 155
2008 Peugeot 207 GT THP 150
Post Wed May 22, 2013 6:32 pm
I will not return to inflating my tyres with air again. I like and believe from experience the benefits of nitrogen.
Post Wed May 22, 2013 6:57 pm
stevebasshead User avatar
Kudos: 326
I'm interested to hear what difference you experienced. Air is 70% nitrogen already and I don't know what to expect from replacing the remaining 30% with more nitrogen. Handling? Pressure stability regardless of external temperature? I know I could Google it but I'm on holiday and 3 Three's 3g coverage is woeful here in the lakes!
Sent from my mind to yours via Tapatalk 2
Post Wed May 22, 2013 7:03 pm
Well here's the article I linked to in full steve.
Nitrogen inflation
For specialist applications only
 You might be aware that purified nitrogen has been used to inflate tyres on aircraft and racing cars for many years but does it really make sense for ordinary car and van tyres?The air we breath (and the normal compressed air used to inflate tyres) contains 78% Nitrogen, 21% Oxygen and 1% other gases but some tyre specialists are now offering - at a premium - to inflate tyres with pure nitrogen.
Nitrogen for aircraft and F1 tyres
Planes fly at heights where temperatures may be as low as -40C. Moisture in the tyres can freeze causing vibration and balance problems when landing. Pure nitrogen is dry so eliminates this problem. Using dried compressed air could achieve the same thing.In motor sport, the elimination of moisture in tyres through the use of pure nitrogen (or dried compressed air) can help reduce tyre temperature when operating in extreme conditions, close to maximum load/speed.
Nitrogen in car tyres
For passenger car tyres the main claims seem to be:
Less corrosion – because unlike air there's no moisture in pure nitrogen
Slower rate of pressure loss – nitrogen molecules are larger than oxygen molecules (which make up 21% of compressed air)
Air loss can occur through the inner liner of the tyre as well through the valve, punctures, or failure of the seal between tyre and wheel rim. Pure nitrogen might leak more slowly through the liner, but you would still have to check tyre condition and pressure regularly.Corrosion of the tyre from using normal compressed air is unlikely anyway because only the outer tread band of a car tyre contains steel – the amount of moisture reaching it from the inside is minimal.
To change to nitrogen you have to have the air already in the tyres removed before the tyres are re-inflated with purified compressed nitrogen. There will be a one-off charge per tyre but once filled with nitrogen, future top-ups would have to be with nitrogen if any advantages are to be maintained.
Overall, while accepting the possibility of purified nitrogen being of benefit in certain applications, we don't think that the cost and possible inconvenience are justified for normal passenger car use.
Post Wed May 22, 2013 7:13 pm
And here's what the tyre manufacturers say,
"Goodyear Tire & Rubber Co. is ambivalent about the use of nitrogen... Michelin goes a step further. They recommend nitrogen ONLY for tires used "in high risk environments” like aircraft landing gear and racing."
Taken from:
http://www.thetruthaboutcars.com/2007/1 ... -nitrogen/
More on the topic:
"In truth, most drivers are going to wear out their tires long before the rubber will decay enough to lower tire performance or safety; those radials will last until much of the gas– any gas– seeps out. I repeat: whether you drive a lot or a little, internal tire degradation isn’t much of a worry.
Proper inflation is the real issue"
Or from another source, " You will not be able to feel any difference in the ride or handling or braking, unless your tire pressures were seriously out of spec and changing to nitrogen brought them back to the proper numbers."
Post Wed May 22, 2013 7:49 pm
Kudos: 732
Yip it was 5th gear.
BORN JULY HOPEFULLY
18" CADIS ALLOYS
Post Wed May 22, 2013 9:32 pm
jactac User avatar
Kudos: 508
This is far too techy. :crazy:
From now on it's custard for me. :thumbup:
Front RCZ Splitters
380/360 Led DLR's
Post Thu May 23, 2013 4:59 am
MaX83 User avatar
Kudos: 215
Did that episode explain why nitrogen filled tires performed not as good as air filled tires?
Post Thu May 23, 2013 5:06 am
MaX83 User avatar
Kudos: 215
Funny thing, this episode will be on telly Friday... LOL, guess i dont have to watch the episode anymore :greetings-wavingblue:
