Board index Peugeot RCZ Peugeot RCZ Technical Discussion Wheels, Tyres & Brakes and Suspension Disc lip R
Disc lip R
Post Sat Mar 10, 2018 7:39 pm
Mrker50 Member
Kudos: 12
On the R when the discs are new is there a lip or smooth from edge to centre .thanks
Post Sat Mar 10, 2018 7:51 pm
Mrker50 Member
Kudos: 12
As i have only had the R a week from a main dealer and was serviced and pre purchase checked out.
Still under warranty .
I know brakes wear .just wondering when a lip is bad.
And been told of the cost of these discs. and main dealer only i think.
Post Sat Mar 10, 2018 8:06 pm
Mrker50 Member
Kudos: 12
Harping on here a bit.ive just had a better look and there is rough gess about 2mil lip.
But looks strange like the edge should be there.if you get my drift.
Post Sat Mar 10, 2018 9:18 pm
Kudos: 1078
It’s my understanding that any brake disc should originally be completely flat (no lip). I have also heard of discs being “skimmed” to remove any lip that has formed. The only issue here is that you do need a minimum thickness on any disc for it to be both legal, and more importantly, safe.
Excess lipping can cause brake squealing (other things can cause this too).
Brand new pads should sit (more or less) in the same “groove” that the old pads have worn into the disc, however, the fit is not likely to be perfect, so the edges of the new pads can be worn excessively at first if the discs have noticeable lipping, this can also affect braking, which is one of the reasons it’s wise to break new pads in carefully after first fitting.
So, to answer your question, the disc should be smooth to the edge.
Post Sat Mar 10, 2018 9:25 pm
Kudos: 158
I've just bought new discs and pads for the front of mine. Going to try and get them fitted next week.
Sandra, 2011 200 GT. Shark grey, Ulter Quad exhaust. Vision pack.
Post Sat Mar 10, 2018 11:07 pm
Kudos: 1467
Have you got photos Mrker50?
Post Sun Mar 11, 2018 1:08 am
Mrker50 Member
Kudos: 12
Hi.can take one.dont know how to upload though.
Post Sun Mar 11, 2018 1:10 am
Mrker50 Member
Kudos: 12
How much were the disc pads.if you dont mind me asking
Post Sun Mar 11, 2018 1:11 am
Kudos: 158
Yay have a random thank.
Use Tapatalk it's easy that way, take a phone picture then add to the forum.
