Board index Peugeot RCZ Peugeot RCZ Technical Discussion Drivetrain Air Hose Removal Advice Please
Post Wed Jul 03, 2019 2:25 pm
pete.garratt Senior Member
Kudos: 169
Any one know the best route to access the clip that secures the air hose from the air box to the intercooler - the one that runs over the top of the engine at the left hand side (viewed from front)?
Is it from underneath or through the wheel arch?
Moroccan Red R
JBL
Black Mirror Caps
Post Thu Jul 04, 2019 7:22 am
OkeyStokey Member
Kudos: 30
Im not sure exactly which one you mean, hopefully the following pics may help?
I would guess part #1?
Post Thu Jul 04, 2019 10:32 pm
Kudos: 169
Number 1 in your first picture.
Moroccan Red R
JBL
Black Mirror Caps
Post Fri Jul 05, 2019 7:43 am
OkeyStokey Member
Kudos: 30
Well all it mentions about that part (Turbo Air Union) is;
1. Disconnect the connector at "a".
2. Loosen clips 2 & 13.
3. Remove turbo air union.
Makes it sound easy uh?
Maybe someone with access to the online catalogue would have more luck?
Post Fri Jul 05, 2019 8:22 pm
Kudos: 169
For more info., it’s a R version and I can’t quite see the best access to undo the clip that secures the air hose to what I guess is the inlet manifold. It’s a bit buried between the bulkhead and engine, so I wondered what the best way to reach the clip fixing was?
Moroccan Red R
JBL
Black Mirror Caps
