Board index Peugeot RCZ Peugeot RCZ Technical Discussion Drivetrain Mk2 chain rattle
Mk2 chain rattle
Post Sat Aug 06, 2016 1:42 pm
Mcb2007 Regular
Just out of interest how many others have had the timing chain rattle on the mk2 1.6 TPH156 engine .
Apart form Boroboy and myself, and did they sort it under warranty without issue.
Post Wed Aug 10, 2016 2:09 pm
Mcb2007 Regular
Cool, nobody else just us two that bought the Friday afternoon specials .
Post Wed Aug 10, 2016 4:13 pm
Kudos: 1155
Mine's a 200 & (touch wood) been OK to date. It's 3 years old next month 26k. Goes in for its 3rd service on 6th September. They are also doing its 1st MOT :o
Post Thu Aug 11, 2016 12:30 pm
Boroboy Member
Just got ours back. Hard to tell yet if it's sorted all of the engine noise. How's yours now from a cold start?
Post Thu Aug 11, 2016 1:04 pm
Hi, mine 156thp needed replacing at 17k just out of warranty but because the car had full service history by indi garage Peugeot didn't want to know!
Luckily indi dealer l bought it from had to pay Peugeot to do the repair.
Two years on and All's well although I've only covered another 7K in that time. :beer:
Post Thu Aug 11, 2016 4:23 pm
Mcb2007 Regular
All seems good so far no rattle ,fingers crossed .
Post Sat Aug 13, 2016 11:43 am
Lynnie Regular
Just had mine sorted, it's the time chain tensioner, not expensive, but if that doesn't cure it, then you need a ne chain and that's what will be expensive.
Post Sun Aug 14, 2016 7:32 am
Mcb2007 Regular
I hoped they checked your chain for any stretch , mine was just out of the tolerance range so they changed that ant the guides . You would have thought they would have replaced yours as a good will gesture . Are you covered under warranty ? Or was it down to cost.
Post Thu Mar 30, 2017 6:40 pm
rcz_r1 Regular
Peugeot replaced the chain tensioner on my Rcz R last week after an oil leak. The car still under warranty.
It is from the 2014 and has 34000 km now.
This is a video of the engine sound this afternoon. Do you find this a notmal sound?
https://www.4shared.com/video/9ChNq4icei/trimE6811D9B-EEFA-468C-ABD0-1A.html
Post Thu Mar 30, 2017 7:13 pm
Hi no that don't sound right needs to go back to dealers asap. :eusa-think:
Post Fri Oct 20, 2017 10:34 pm
mmssgg Newbie
It appears to be a "known" problem and pretty poor showing that these timing chains on the petrol are going down as well as causing engine damage in some cases - what has Pegout done about this?
During a service by Pegout, is the timing chain and tensioners checked?
The car we bought is the rarer automatic.
All help appreciated.
Thanks
Post Sat Oct 21, 2017 7:33 am
Sanity Senior Member
mmssgg wrote:
Hi
However, been reading re 'timing belts/chains' - this appears to be a known problem.
Thanks
Yes its a known problem.
No they dont check during a service.
chain rattle from engine bay on a cold start will most likely be a indication of a replecement needed.
156hk engines are more present with this issue then the 200hk.
on Diesels this isnt a issue as they have belts instead of chain.
Post Sat Oct 21, 2017 2:57 pm
mmssgg Newbie
ok, thanks
I am a bit surprised that a design fault is allowed to go on for so long without being rectified and revised parts.
Post Sat Oct 21, 2017 3:51 pm
Kudos: 208
There are revised tensioners.
Post Sat Oct 21, 2017 9:07 pm
There is a revised tensioner and guides which are a little beefed up. One of the issues is that with the tensioner being hydraulic it needs a plentiful supply of good quality clean oil, some of these engines seem to use a little oil so need to be kept an eye on the level, also I’ve heard Peugeot are now recommending using Total ineo first as your regular service oil, this is the oil Peugeot use in brand new engines.
Post Sun Oct 22, 2017 9:05 am
Boroboy Member
Unfortunately these engines suffer from numerous issues. Down to bad design. Same engines that are used in the mini cooper s, some BMW's too. Timing chains should not be failing at these mileages. I've always kept an eye on my oil level, serviced by the main dealer.
