Board index Peugeot RCZ Peugeot RCZ Technical Discussion General Technical P0087 fault code
P0087 fault code
Post Tue Jul 03, 2018 2:03 am
braveheart Member
Kudos: 24
Hi guys is this fault code HPF pump or a sensor and does anyone know of a recall on this i have a 2010 156 with 60k thanks in advance
Sent from my SM-G930F using Tapatalk
Post Tue Jul 03, 2018 7:18 am
You'd probably get nowhere on a car that age.
Besides, I'm sure they're not that expensive.
Whether or not you'd fancy doing it yourself is another matter.
Post Tue Jul 03, 2018 8:04 am
Do you have an obd dongle? If so, you can read the fuel rail pressure at various driving conditions to determine what's going on.
Post Tue Jul 03, 2018 5:59 pm
In my case, P0087 fault code meant new HP fuel pump (at around 80k km / 50k miles). Since this is pretty common issue and usually happens before 100k km, i think you will need new HP fuel pump :eusa-whistle:
