Board index Peugeot RCZ Peugeot RCZ Technical Discussion General Technical Dash Display Parameters
Post Tue Jun 26, 2018 1:14 pm
beaks User avatar
Kudos: 42
Hi all,
Quick one - one my dash display I can select the big MPH readout with instant MPG and range below.
Is there a way of changing the parameters below to average MPG etc?
Clearly not a big deal it not, but I find the instant MPG pretty useless unless on cruise control...
Cheers,
Ian B
@teambeaks
Post Tue Jun 26, 2018 7:22 pm
Pressing the button on the end of the windscreen wipers changes the display, but it will change from the big speed numbers to average speed, mileage etc
Post Tue Jun 26, 2018 9:24 pm
beaks User avatar
Kudos: 42
Hi, sorry yes I know you can cycle through using that button...
My question was can you change what's shown below the MPH display?
Cheers,
Ian B
@teambeaks
Post Tue Jun 26, 2018 9:49 pm
Kudos: 1158
I don’t think you can change that display using any stock controls.
I think there are various parameters that can be changed using Mirascript, I have changed what happens when I press my mode button & the end button on the wiper stalk, but it was quite a lot of trial and error. viewtopic.php?f=20&t=10474&hilit=+Software
The main problem is that if you do anything that you can’t correct you have a brick. I don’t know whether or not you can achieve your goal even using Mirascript.
The above only applies to the RT6 unit, not the NG4.
Post Wed Jun 27, 2018 8:48 am
beaks User avatar
Kudos: 42
Hi,
Thanks for the info - given the risks involved I'll leave things well alone!
Cheers,
Ian B
@teambeaks
