Board index Peugeot RCZ Peugeot RCZ Technical Discussion General Technical Possible recall
Possible recall
Post Fri Mar 02, 2018 5:30 pm
Kudos: 594
Hi guys, called into my local dealership today to pick up some coolant and the parts guy informed me there we’re a recall notice on my car regarding the replacement of the turbo cooling pump and asked me to book it in for them to sort. Now when I went to the service desk and explained why I wanted to book my car in the knowledgeable lady behind the desk said it was just a software update for the turbo cooling pump and then if that showed and issues the pump would be replaced and according to her only affected 1 % of vehicles so booked in next Friday and will let you know the outcome.
My car is an early Z being a Launch Edition so don’t know if any other models are affected but the service desk said they wouldn’t have notified me unless I had booked the car in for something else which would be rarely as I use an independent mechanic so I’m tipping there may be loads out there that need this looking into may be worth a call to your local dealer to see if yours is one of them :beer:
Post Fri Mar 02, 2018 5:40 pm
Kudos: 561
You should be able to check if there are any recall notices for your cars here: https://www.gov.uk/check-vehicle-recall or here: https://www.themotorombudsman.org/vehicle-recalls :thumbup:
Post Fri Mar 02, 2018 8:18 pm
The problem is, Pug tend to issue “notices” when it is an issue that doesn’t warrant a recall. (I.e. it’s not likely to kill you).
When I had my front strut top mounts replaced, they told me that it was on a “notice” so that they would be replaced FOC only if the owner complained about them. This is a bit sh1t really, it’s saying that they know there is a problem with a certain part, but unless the owner notices, they won’t actually do anything about it.
So in this case, it seems they know there is a problem with the turbo cooling pump, but they aren’t going to tell anyone unless they happen to take their car into a dealership.
Post Fri Mar 02, 2018 8:23 pm
Kudos: 594
Yes exactly Pete this wasn’t a safety recall just a manufacturer note on the ViN.
Post Fri Mar 02, 2018 8:29 pm
:text-goodpost:
Like I said though, this turbo pump issue is a “notice” not a recall, so it’s not listed here.
Makes you wonder how many other “notices” there are that nobody knows about :eusa-think:
Post Fri Mar 02, 2018 11:31 pm
Kudos: 67
My dealer has informed me a Long time ago about this.
Recall for the turbo coolant pump and software update.
Because of the remap i havent Done anything of these and as Long as the car works fine i dont See any reason to do them
Post Sat Mar 03, 2018 2:42 pm
Kudos: 594
Thanks for mentioning that! My Z has been remapped and I hadn’t thought the updates would affect it but as you rightly say it would so looks like telling Peugeot not to do the update. :eusa-think:
Post Sat Mar 03, 2018 7:00 pm
Kudos: 67
Dont know if its possible for the dealer not to do the update
You should discuss this with Peugeot and the person Who made the remap
