Board index Peugeot RCZ Peugeot RCZ Technical Discussion General Technical Weird Electrical noise!
Post Thu Mar 01, 2018 1:37 pm
queenb123 User avatar
Hello All,
I have another weird noise query!
After driving, switching off engine I hear this from the bonnet:
https://instaud.io/1QqB
Sounds like an electrical charge or something...can anyone help with this please?
My car is always fully serviced, very well looked after and only has 11k miles!
Please help!
Many thanks
Post Thu Mar 01, 2018 2:51 pm
Kudos: 1156
It does sound a little like something shorting. Have you had any electrical faults, anything not working correctly or warning messages.
Have you had a listen while the car is running to see if it is doing it then? It might be that you only notice it when the engine is off but that it still does it when the car is running.
Try looking at it in the dark, if it is an electrical short you might see a spark somewhere.
If you can’t find it, it might be worth a trip to the dealer, just to get their opinion.
Post Thu Mar 01, 2018 4:14 pm
Are you sure it not the turbo cooling fan that keeps running until your turbo can cool down by itself, without damaging itself?
Sorry can't listen to file atm.
Post Thu Mar 01, 2018 4:40 pm
I hear all sorts of noises from mine, mainly the turbo cooing down or the brakes cracking and popping, but nothing quite like that.
Lift the bonnet and see if you can pinpoint the location. Good shout from DKZ, have a look when its dark, shorting should be evident then.
Otherwise trip to local stealer but it should be under warranty?
Post Thu Mar 01, 2018 6:21 pm
Did you check the heat shields? Are they loose at all? If they are loose then it might be the heat making them move about and knocking against something else!
Post Thu Mar 01, 2018 6:28 pm
Hi All,
I have no clue about cars i just love driving my rcz!
@ DKZ5745 - no electrical faults or warnings at all - it only happens when engine is off!
@ Everyone else I will play the noise to my BF and see what he says!
Many thanks.
Post Thu Mar 01, 2018 6:29 pm
That sounded like the fan against the radiator was still running.
And it sounded like one or more blades was catching something, maybe a twig, leaf or could be catching on the shroud.
Post Thu Mar 01, 2018 8:56 pm
Kudos: 581
I think it is something spinning that is either catching something or is failing turbo cooling pump?
Post Fri Mar 09, 2018 11:48 am
Ok now so the heating has stopped working - could these two issues be related somehow?
Post Sat Mar 10, 2018 11:09 pm
Have you got the correct amount of coolant?
If yes does the bottom pipe get hot (going to/from radiator) as this could be a sign water pump has failed, as water is not being pumped round the system.
Post Sun Mar 11, 2018 12:04 am
queenb123 just a quick question....
did you get any warranty with your car and did you buy it from a dealer??
I understand it is a low mileage Z and well serviced, but unfortunately you do seem to be having a few problems with the car, and in fairness some of these should have been sorted by the dealer. The noise from before - if it was electrical could well be the reason your heaters not working - though I'd have thought there would of been other signs aswell.
I have had problems with the heater unit on two different Peugeot 307cc's I had and it could be related but with such mileage not likely. Have you checked your service book and MOTS does the mileage come back as correct? just to correlate that they all match up.
cheers and good luck, hopefully you will be able to enjoy carefree driving very soon and start to love the RCZ again.
