Board index Peugeot RCZ Peugeot RCZ Technical Discussion General Technical Speedometer incorrect!
Post Mon Oct 17, 2016 1:59 am
queenb123 User avatar
Hi all,
I have a late 2012 model of Rcz, for some reason my speedometer (I think that's what it's called) give me the incorrect speed while driving...for example I will be doing 30mph and it's telling me I'm doing 80mph!
Is there a way to reset this? Or is this a job for a mechanic????
I have attached a photo of a similar speedometer.
Would appreciate any help as I am trying to save some money!
Thank you!
Post Mon Oct 17, 2016 7:32 am
Kudos: 594
Hi, could it be that your digital speedo is set to read kmh where your analog speedo is a mph unit? You probably just need to go into your settings on the digital screen and alter the setting to mph easy! :thumbup:
Post Mon Oct 17, 2016 2:50 pm
The Kph instead of mph sounds likely.
Whereas mine often says I'm doing over 100 mph :eusa-whistle: :law-policered:
Post Mon Oct 17, 2016 10:28 pm
Kudos: 376
Conversion from mph to kph the kph gives a higher speed than mph
30 mph equals 48 kph
40 mph equals 64 kph
50 mph equals 80 kph
60 mph equals 96 kph
62.5 mph equals 100 kph
If you have the RT6 system press setup, choose select units, and select the units required.
If you have the RT5 system
If you have the NG4 system
Press setup
