Board index Peugeot RCZ Peugeot RCZ Technical Discussion General Technical RCZ-R spark plugs and gap
Post Sun Sep 11, 2016 4:10 pm
Kudos: 378
What spark plugs have been used when you have had a service?
I've just taken mine out to see what part number I could find.
Part number is ILZKR8C8G with NGK IR on there.
I cannot find these on the net and even NGK website doesn't list them.
All 4 spark plugs are 0.72mm gap.
Post Sun Sep 11, 2016 8:01 pm
Little scorched at the top - suppose the THP lump does get very very hot!
Post Mon Sep 12, 2016 10:03 am
Kudos: 286
Sorry, cannot help here as I haven' had them out by myself. And the invoice doesnt tell me which Pug has put in
Post Mon Sep 12, 2016 4:58 pm
thornebt User avatar
Kudos: 17
It's an NGK Iridium plug - top quality. The plug number can be broken down:-
I = Iridium centre electrode and Platinum ground electrode
L = Extra long reach thread - 26.5mm gasket type (i.e. sealing washer)
Z = Extended gap (extra projection)
K = 12mm thread, 1.25mm thread pitch, 16mm hexagon
R = Resistive plug
8 = Heat range
C = Design series (doesn't specify exactly what!)
8 = 0.8mm electrode gap
G (NGK do not specify what this means as far as I can see)
I don't know if any of that is of interest. I couldn't find a plug spec for the RCZ-R as it's not listed in my NGK catalogue. However, the plug spec might be given in your handbook - or someone on the forum will know what it is. Cheers. Bruce.
Post Mon Sep 12, 2016 8:31 pm
Kudos: 378
Been doing a bit of digging around the Internet and apparently the plugs are a supplier only type as in only made for manufacturers not for general re-sale.
They are also in the DS3-R.
But still the question still exists, what do you put in its place when you change them yourself?
Post Wed Sep 14, 2016 1:21 pm
RCZMonkey User avatar
Kudos: 8
i got mine from euro car parts
http://www.eurocarparts.com/ecp/c/Peuge ... 396&000301
£12.50 each, sometimes have discount codes if you google first,
MK1 GT200
ex Alfa Owner
Post Wed Sep 14, 2016 3:59 pm
Kudos: 286
Looks like the official Peugeot Sport store sells them too:
http://www.peugeotsport-store.com/produ ... &id_lang=1
Post Fri Sep 16, 2016 3:38 pm
tony1968 User avatar
Wrong plug for the R, it runs an EP6CDTR engine and a cooler 8 grade plug, that will be a 7 :(
Post Thu Oct 20, 2016 1:41 pm
MagicianRCZ Regular
As you have Iridium plugs these should be good to last for 60,000 miles plus. With the exception of external interference like side pressure snapping the body etc. Most spark plug manufacturer's have web sites where you can cross reference different makes of plug and check the correct type for the engine in your vehicle. Now don't quote me on this but most plugs come pre-gapped to 1.00mm but it pays to double check the gap is set correctly what ever the specs.
Post Thu Oct 20, 2016 1:51 pm
Kudos: 17
On NGK's online catalogue they quote plug type ILZKBR7B8DG for the RCZ 1.6 as an Iridium upgrade to the platinum plug.
95770 PEUGEOT RCZ 1.6 03/10 –> Upgrade
These are available on Ebay. Cheapest deal is £9.49 per plug with freepost.
Cheers. Bruce.
Post Sun Oct 23, 2016 12:06 pm
R plugs are replaced every 10k/1 year service :)
Post Sun Oct 23, 2016 3:53 pm
Kudos: 378
10k/1 year is for arduous conditions.
12.5k/1 year is for normal conditions.
Post Tue Oct 25, 2016 9:16 am
RCZ_PL User avatar
You can find in NGK catalogue:
https://www.ngk.de/nc/pl/wyszukiwarka-p ... 8DG/11120/
PEUGEOT > RCZ 1.6 200 THP
kW: 147
06.2010 -
Engine code EP6CDTX
sparks: type:
ILZKBR7B8DG
Stock No.:
95770
you can use also BOSCH – 0 242 135 518 or DENSO – VXUH22
Post Tue Oct 25, 2016 12:15 pm
kW: 147
06.2010 -
Engine code EP6CDTX
sparks: type:
ILZKBR7B8DG
Stock No.:
95770
Not the right plugs for the R as the engine type is different and those plugs are a 7 and the R uses an 8.
Post Tue Oct 25, 2016 12:35 pm
Kudos: 17
The link above looks like NGK's Danish site? But the NGK UK online catalogue has the same plug spec:-
http://www.ngkpartfinder.co.uk/car_comm ... engine=all
RCZ 1.6 EP6CDTX / 200ps 03/10 –> ILZKBR7B8DG 95770
It might be that NGK have an error in their catalogue.
Cheers. Bruce.
Post Tue Oct 25, 2016 9:52 pm
Kudos: 378
Found these on Peugeot-Sport website
