Board index Peugeot RCZ Peugeot RCZ Technical Discussion General Technical Flip up sat nav
Flip up sat nav
Post Sat Jun 25, 2016 9:52 pm
Timmy264 Regular
Kudos: 14
Had a flickering sat nav screen. Took the screen out and it was obvious where the fault was. The cable twists each time the screen opens and a wire was broken. Took it apart and soldered in a new section. If anyone wants some cable to repair their own foc,just pm me and send a sae. Had to buy 50 meters but only needed 1!! ImageImageImage
Sent from my iPhone using Tapatalk
Post Sun Jun 26, 2016 1:01 am
Kudos: 1173
:clap: :text-goodpost:
Post Sun Aug 14, 2016 12:34 pm
tony4liz Newbie
Hi, your post on the sat nave problem is illuminating. I think I have the same problem. any chance you can give me a clue as to how to remove the unit to check? Then I feel sure that i'd want to buy some of your spare cable
Tony Marsh :helpme:
