Board index Peugeot RCZ RCZ Tuning & Modifying Forum Front brakes upgreade
Post Mon Jun 25, 2018 8:50 pm
Kudos: 65
Im looking to upgreade my front brakes with rcz's 200
Except from calipers and discs does anyone know if i need anything else?
Can anyone See from the service box which are the differences?
Post Mon Jun 25, 2018 10:17 pm
Have you had a look at rczperformance.co.uk to see what Steve has on there?
Post Mon Jun 25, 2018 10:25 pm
These are for the 200bhp
This is the list of all front brakes for the RCZ's
Post Tue Jun 26, 2018 7:53 am
Kudos: 65
first of all thanks a lot!
secondy i don't undrestand anything...
thirdly i know that thp 200 has bigger calipers and discs, i meant if the the edges where the calipers are connected (sorry i cant find the words) have any differences
probably i will just find 2 calipers and i will find it out in the future
Post Tue Jun 26, 2018 10:26 am
I assume what AEK is asking here is, if the mounting brackets of the 200 will fit plug&play to his 156 or does it require more parts (like suspension parts) to be swapped before the 200 brakes will fit. :greetings-wavingblue:
Post Tue Jun 26, 2018 1:15 pm
Kudos: 65
Exactly that!
Thanks a lot for the help
Post Wed Jun 27, 2018 7:39 am
Joske User avatar
Kudos: 58
The easiest way to find out is to check servicebox for the HDi version.
If the wheel hubs are for all HDi's the same it will fit.
The HDi came with standard 18" wheels with the same brakes as the THP156
but if you choose the 19" alloys (like I did) Peugeot upgraded the brakes to the THP200 ones.
- Peugeot RCZ HDi GT - Image
- Peugeot 309 GTi16
- Peugeot Partner 170C
Belgian Peugeot enthusiasts: http://www.peugeotforum.be
Post Wed Jun 27, 2018 8:32 am
Kudos: 65
i don't think that's correct
thp200 could also be bought with the 18" rims
hdi and thp 156 could also be bought with the big brakes if you had chosen the sport package (it also included the smaller steering wheel etc) so there are more differences than just the rim size (at least here in greece)
which steering wheel do you have?
Post Wed Jun 27, 2018 11:26 am
Joske User avatar
Kudos: 58
If that is the case, than the brake calipers will fit both.
I speak for Belgium.
Bigger brakes were only option on the HDi together with the 19" rims.
Sport pack on the HDi included smaller steering wheel and shorter shifter (and soundbox in the thp156)
- Peugeot 309 GTi16
Post Wed Jun 27, 2018 11:51 am
Kudos: 65
Then you are probably right
Eitherway i am looking for the calipers and When i found them the mystery Will be solved
Post Wed Jun 27, 2018 7:52 pm
beaks User avatar
Kudos: 42
doesn't the 200 have different hubs to the 156?
i guess it's all down to hole spacing - but to me putting stuff onto hubs that (potentially) aren't made for the job is a dangerous game...
just my opinion, of course...
ian b
@teambeaks
Post Wed Jun 27, 2018 8:09 pm
I'm sure the 200 has 407 front hubs and suspension.
Unless I made that up.
Post Wed Jun 27, 2018 8:52 pm
Guppy Senior Member
Kudos: 110
ian b
I believe you may be correct breaks?.... the front hubs on the 200 bhp are bigger, as are the hubs on the R.
Red Carbon 200
Post Thu Jun 28, 2018 7:49 am
Kudos: 65
ok i have a silly question
when you say front hubs what to you mean?
Post Thu Jun 28, 2018 8:16 am
What the discs and suspension attach to.
Post Thu Jun 28, 2018 9:48 am
Kudos: 65
Tianorth can you confirm that?
Post Thu Jun 28, 2018 9:45 pm
For the 156 bhp - Hubs
PM me your Vin number and I'll get you your part numbers.
Post Thu Jun 28, 2018 9:49 pm
Brakes for 156ImageImage
Post Thu Jun 28, 2018 9:52 pm
For the 200bhp - HubsImageImageImage
Post Thu Jun 28, 2018 9:54 pm
Brakes for the 200 bhpImageImage
