Board index Peugeot RCZ RCZ Detailing & Car Care Brake Calipers
Brake Calipers
Post Mon May 25, 2015 3:47 pm
highlander64 User avatar
just spent the last couple of days doing my brake calipers, well pleased how they have come out
Just got one left to do but i can not get off the security nut,looks like its been put on with a impact driver :thumbdown: and it just keeps slipping off any ideas anyone please ??
Post Mon May 25, 2015 5:50 pm
sorry i can't help but the car does look well :thumbup:
Post Mon May 25, 2015 7:14 pm
Thanks Renegade :thumbup:
Post Mon May 25, 2015 8:24 pm
howardf Senior Member
Kudos: 66
I've used these guys before
http://www.cylex-uk.co.uk/reviews/viewc ... d=12970416
it looks frightening but 100% success and no damage to alloy wheels.....
i went direct to the firm and they charged per nut, it sounds like the RAC and AA carry them, maybe you should have a "puncture" ;) ........................H
Front & Rear sensors
19" Black Onyx Solstice
Post Mon May 25, 2015 10:20 pm
Thanks Howard, that is one handy kit to have, I never thought about the AA i have a mate who works for them ill see if he has one on board :thumbup:
Post Mon May 25, 2015 10:42 pm
I'll be honest, I find the wording, "making it an ideal solution for anybody looking to remove locknuts without the key", a little disconcerting!! So essentially the perfect tool for anyone looking to help themselves to sets of alloys!! :o
Post Mon May 25, 2015 10:58 pm
wrapper Banned
Banned
Kudos: 73
:shock: :o
Despite three temporary bans and various warnings, I continued to behave like a dick and got banned permanently.
Post Mon May 25, 2015 11:16 pm
My local Pug dealer trashed 3 out of 4 of my locking nuts when they last had my car in. They then said I had done it, and I had to pay them £40 to get the old ones off and replace them with a new set.
Once the collar has slipped on the locking nut, the whole set has to be replaced. The tricky bit is getting it off. They managed it, but it took some time. They didn't damage the alloys though.
The damage happens if the nut is over tightened or of the key-socket is not put on correctly before pressure is applied.
I know a few on here have had the same problem and have replaced them with normal nuts. It appears to be another one of those problems that loads of owners has, and that Pug say never happens, and if it does, it must be the owners fault.
Even the garage that broke mine told me they had had the same problem many times :wtf:
Good luck
Post Tue May 26, 2015 7:27 am
SEVEN7SEV3N Senior Member
Kudos: 44
Hi, looking good. I really want to do this to my brake calipers, but have been putting it off due to the sill problem!!!
May I ask how you lifted the car, to remove the wheels ? Did you bother painting the rusty brake disc hubs as well ?
Equipment used and point of lifting please..
Post Tue May 26, 2015 10:23 am
Kudos: 157
For the front, I've taken to driving over some 30-35mm planks (to get clearance for the jack) and lifting under the subframe.
For the rear, I jack under the crossbeam (even though there's a label saying not to).
Post Tue May 26, 2015 1:52 pm
Kudos: 378
The problem with using the crossbeam is that it contains the torsion bar which needs to twist freely in the torsion tube (crossbeam) if it is put out of shape it will prevent the bar from twisting properly.
I have had one of my front jacking points collapse, but the rear ones are better as less weight on. Just be careful when jacking. Because the chassis is stiff you will find by jacking up one side of the rear, both rear wheels come off the ground.
Post Tue May 26, 2015 9:37 pm
Hi Seven
I used my trusty old trolley jack which when lowered slips nicely under the cill (which i keep in a box in the boot after bad experience with a cheap scissor jack supplied with my old Citroen) and used the jacking points as in the hand book and did just one corner at a time.
I used Halfords break cleaner wire wool and a tin of red Halfords caliper paint
Post Tue May 26, 2015 9:39 pm
close up
